NMDriver
Jun 24, 2015Explorer
I do not think two hours/day will recharge batteries that are under heavy use, however...I am no 12V guru, (there are several on the tech forum) and, that being said, I will assume you are not using the furnace (it is summer time) and since daylight is lasting until 20:30 or so you will not need much lighting, and your pump does not run constantly, so with those assumptions I believe you will be ok for several days.
You might mention where and for how long you plan on being off the grid.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 11, 2026
