valhalla360
Jun 24, 2015Navigator
You should be fine for a weekend. Just don't try and use the 12 volt outlet on the generator. It doesn't put out much. Plug in as if you are at a campground.
Realistically, you will only get up to 80-90% of full charge with 2 hrs per day but that's OK.
Assuming it's a pull start generator, your worst case scenario is a dead battery in the morning that you charge back up.
If this is something you are going to do regularly, you should look into your usage more and make sure you aren't being hard on the batteries but for a one off weekend, you should be fine if you keep your usage limited.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
