bpounds
Jun 25, 2015Nomad
We boondock a lot, so we use the genset a lot. Here are some things I've learned.
Plug your regular shore cord into the genset. Let your onboard converter do the charging. The 12VDC outlet on a genset is just about worthless.
Run your generator at least a couple of times a day, and start on the very first day. Don't let the batteries get down before you try to bring them back up. It is easier to keep them topped up, than it is to recharge from a low state.
Splitting your charge time to morning and evening, or even 3 times a day if you feel like it, allows the batteries to rest between charges, and they will take on charge better than if you try to run once a day for longer.
Make sure your fridge is on propane. No sense using what AC your genset is putting out to run the fridge. Likewise, and even more important, make sure your water heater is on propane only. We never bother using AC on our WH, so the switch is permanently in the off position.
Combine your charging time with other power consuming things, like using the pump to take showers. You'll get a better shower because the pump will run better on the high voltage your converter is putting out, and that is just that much more juice that won't be sucked out of your battery. Same with washing dishes. And if you like to watch movies, a good time for that is while the genset is running.
Small things matter. Like when you first park on your site, leave your truck running and the umbilical connected to the trailer while you operate your landing gear and your put out your slides. Those use major 12VDC juice. No sense losing that juice in the first 5 minutes of your trip. Those motors will thank you too.
All living area lights should be LED. Makes a huge difference in power consumption.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
