Braveheart's avatar
Braveheart
Generator gas tank.
So, after 8 years with a trailer I finally made the switch to an 05 fleetwood gearbox 300FS. If there is anyone out there that has one, I would like to pick your brain.
In regards to the generator, a 5.5 Onan. The original owner said he recently had the generator serviced (440 hours) and put in fresh gas, but I tend to doubt him. Assuming the gas is old what is the best way to handle the situation? Same with the gas in the toy gas tank. Bot tanks have approximately 1/3 of gas in each.
  • Are you sure the tanks are only 1/3 full? Is the gas less than 6 months old? If so, just top them up with fresh gas and you should be okay. My Jayco Octane will sit around with up to 6 month old gas, and I haven't had a problem just refreshing the old gas with some new. Gen set ran fine.
