Lantley wrote:
While I understand some may be not concerned about sound. Decibel rating is an important parameter for most.
When it comes to sound it is not so much about the users interpretation of the sound. It becomes more important to consider the generator sound's impact on those in the area close enough to hear the genset
BINGO! So often people post "Oh my generator is quiet. I can barely hear it". What they are not saying is that they are not outside listening to the thing roar away at 3600RPM using it's full potential output or not.
Your generator can be heard from a long long way away. It may not be loud but it is there.
Yes, there is a need for generators but if getting one, get an inverter generator. It produces PSW 120VAC. It will spend most of the time not much above idle. It will be much cheaper to run. It is truly quiet. Your neighbours will smile at at you instead of scowling at you.
