johndeerefarmer
Dec 23, 2016Explorer III
We Cant Wait wrote:
I'd keep a REAL CLOSE EYE on the rack and mounting points. Yes it's rated for 300lbs, and the generator is 194lbs. But with the distance from the rear axle to the rear of the TT you will experience quite a bit of bouncing at the read and the Generator bouncing weight/force could easily exceed 300lbs.
I am NOT CONCERNED AT ALL- I have faith in my engineering and welding. Lippert/GD specifies 300 lbs static load. They do not specify dynamic load but you can be sure that they accounted for it. Since most will mount one of those Harbor Freight cargo racks on the back -which just happen to also stick out several feet past the rear, as do the folding cargo rack rated for 500 lbs that many RV's come with.
About Fifth Wheel Group
