djousma
Oct 01, 2019Explorer
hiker108 wrote:
I have Yamaha EF2000iSv2 generator.
When RV is hooked up to house A/C and just charging battery (with converter on) my handy dandy watt monitor shows it drawing less than 2 amps.
If I connect RV to generator, I can run lights and heater, etc (approx 6 amps) with battery disconnected. However, if I turn off converter and have battery hooked up, with generator running, it stalls out if I then turn on converter breaker. Watt meter is still showing only 1.6 amps as the generator bogs down and stalls. Weird that this doesn't happen with battery disconnected and OTHER 12 volt stuff turned on!
Any thoughts??
Ed
Ed,
I see from your signature that you are in Colorado? At what altitude? Most of the generator manufacturers offer a high altitude kit that is just a leaner carb jet. Its not uncommon for any generator to make less power at the higher altitudes.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
