djousma
Oct 09, 2019Explorer
frankwp wrote:
I have a Honda EU1000 that won't run the on board charger either. With all 120V circuits turned off, the generator overload cuts out immediately when the trailer is plugged in. Not sure what is going on here. The carb has been cleaned & it runs fine.
If you have electric water heater, make sure that is off too. On mine that switch is on the WH itself. that element is a 1500 watt, and would for sure kill that EU1000.
Otherwise, is your battery dead or heavily discharged? If so the converter will kick on high output to recharge, and could be your issue too.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
