MainerBob's avatar
MainerBob
generator storage
I am planning to get either a Honda or Yamaha 2000 size generator so we can do more dry camping. My query is about carrying it. The front storage compartment on my Everest is certainly strong enough for the weight but what about gas fumes? The jack motor is in there and on the outside left is the propane compartment and in the right outside compartment are the batteries. Over head inside is our bed. Is this a bad idea? I want to keep it (and us) safe and out of sight.
Also, are these two the favorites or are there other choices? I want the quietest but also the best quality.
  • If we're using them on the road and the weather is dry, I'll carry our 2 each Yamaha EF2000iS generators in the bed of the truck, suitably cabled and locked. If the weather is "iffy", we have covers for the generators.
    If we're not using them and the forecast is for rain, I can just fit both generators side by side in the QuickDraw cargo drawer in the basement where they take up minimal space. The Yamaha EF2000iS generator has an on/off selector on the fuel tank cap that, in the off position, seals off the fuel tank so that gasoline vapors are not a problem if the cap is properly tightened.
    Rusty
  • Basic options:
    - Rack on the back: Downside, it tends to be bouncy and the typical sewer pipe tube is a little iffy for holding it.
    - Back of the truck: Downside, less convient if you want to take the truck while the wife stays at the trailer.
    - In a dedicated storage space: Eats up valuable storage space.
    - Mount on top of pin box: Without electric start, may be hard to start if you are short.
    I would recommend against just sticking it in any old storage space. As you noted, there are potential spark producing items that could set off any fumes that accumulate. Not to mention, a good probability, the odor makes it's way into the living space.
  • I have a "Geardeck 17" on the back and carry a Champion 3100 Inverter. I can prop the lid open to serve as a rain cover and run the Genny from there. Others recommend carrying in the truck bed.
