motc777 wrote:
bpounds wrote:
This is an RV forum, so you got RV answers, so far.
But consider, if your power is going out frequently now, it will go out frequently to your new house too, right? So why not consider a full house generator now. Use it to power your RV now, and switch it to power your home when it is complete. Probably a discussion to have with your general contractor, not an RV supplier.
Way ahead of you on this one. Part of our home plans include wiring for and putting a generator on the house to run everything.
What I would like to have for now is a generator that we can specifically move around and take with us in the Fifth Wheel should we ever need it.
Since you're talking about using it later on, you're pretty much locked into a quiet inverter-style generator; Honda, Yamaha, etc. 3k =minimum=, and that will run the A/C and charge the battery(ies), but not much else. I'd want a 3500-4000w to be comfortable. Frankly, unless you're well-shaded, one A/C is just barely going to keep you comfortable.
Lyle
