jmac2009's avatar
jmac2009
Generator to run AC
This Friday I take ownership of a new 2014 Forest River Silverback 33RL. My wife and I plan to go off grid for most vacations to get away. The 33RL has two AC units, a 15,000 BTU in the main room and a 13,500 in bedroom. I am trying to find a solution to running only ONE generator at a time at night but not have to carry or manhandle a 150 to 200 lb generator.
Wow, I would have thought that finding a small portable generator to run a 13,500 BTU AC generator at bedtime and that could be combined to run in parallel with another for running a 15,000 BTU AC during the day would be simple. Wrong. The best would be to have two generators so one can be backup at night. I can live with more heat during the day but I have to have a cool room to sleep.
After searching the web, I don’t seem to be able to find a solution with all inverter generators on the market. When will someone design a 2500-2800 to run a 13,500 and then combine another 2500-2800 to run a 15,000 RV AC?
Am I missing something
  • For my money I would go with the Honda! They are very reliable!! After hurricane Andrew in South Fla I purchased a honda generator in case of another "power outage". In 2004 in Central Fla where we moved to we had 3 hurricanes one after the other, I got out the Honda a tried to start it, it would not kick, after all it was 14 years since it ran. Then I realized that I did not turn the key to "ON", it started immediately!!! WOW I will never buy a different brand of generator! That to me was amazing!!!!!
  • I have a new Yamaha 2400 and it runs my 13.5 AC fine.
    But my big complaint is the noise. It is really loud.
    You might have the neighbors complaining.
  • the bear II wrote:
    Do an internet search for a remote start on a Honda 3000. I've seen them advertised in RV magazines and found the company with an internet search a few years back. They had a parallel kit to hook two 3000s together.
    The remote start saves you having to run outside in the cold or heat.
    Yes, I found that 1 Honda EU3000i can run a 13,500 AC and it can run parallel with another Honda EU3000i which I sure can run the 15,000 BTU AC but wow, $2300 each. However the 3000i is only 80 lbs to move around which is doable.
  • Do an internet search for a remote start on a Honda 3000. I've seen them advertised in RV magazines and found the company with an internet search a few years back. They had a parallel kit to hook two 3000s together.
  • We've two Yamaha 2400is generators that can be hooked together (their older models), but I usually just run one. It'll power the AC, big TV (40") and some lights all at once. If we're going to be boondocking for a while in heat, I'll bring the second and have 30 amp capability. Each weighs about 80 lbs so I can move them about without a lot of hassle.
  • We use two Honda EU2000i generators with Companion Kit with Parallel Cables. They run our 15000 BTU AC unit (Coleman unit) in the living room of our 5er.
