dsrace
Dec 06, 2020Explorer II
Traveling Platypus wrote:
I found the dimensions, thanks for the offer.
Where did you find the longer bed guides?
just saw your reply. glad you got the measurements. i personally run the anderson wd hitch with sway control.....works very well even in 45mph cross winds.
the longer rails were ordered directly from happijac. i have all the p/n #'s if you want to make the change. that bedframe is only rated for 300 lbs so if you and another exceed that then make a support leg to sit under the bed. it can be a free standing leg/post that folds up or breaks down for storage. very simple, rail swap took 4 hrs.
About Fifth Wheel Group
