Deryll1
Jul 19, 2017Explorer
Genesis supreme tire wear
Hi everybody, I am curious if anyone owning a Genesis ( 5th wheel) that has a lot of wear on their tires , I mean outside only?? Anyone? Let me know what you guys experience, thanks!
Deryll1 wrote:The first step in solving any mechanical problem is a proper diagnosis. It appears that you have found one potential cause. I would NOT as has already been suggested (it always is) have the axles bent to fix the alignment.
Thanks for the reply, I measured the brackets that connects the leave springs to the frame to the front of the trailer and back of the trailer, my driver side is over 1/4 inch further back then the passenger side. I don't know what the specs are, but I thought that both sides should measure the same in order for the axles to be parallel with the frame. I met a guy from Sedona, almost same trailer, he had exactly the same wear pattern as mine. Mine has now 2400 miles on it. Pattern as followed:
Driver side front: perfect
Passenger side front: badly worn down( not safe anymore)
Driver side back: really noticeable wear on outside only.
Passenger side back: really noticeable wear on outside only
How can it be that we have the exact same wear pattern?
