Lantley
Jun 04, 2017Nomad
dpgllg wrote:jmtandem wrote:We looked at a 2017 Grand Design Reflection 27RL yesterday and fell in love with it. Did the paperwork and it should be hitched to my truck in about 10 days
I don't think you are asking all the right questions. You will likely be close to or even slightly over your truck's payload capacity with the gross weight of the fifth wheel at just under 11,000 pounds. Add in the hitch weight and 20 percent of the fifth's weight on the pin and you will be at or over 2200 pounds before you put anybody, dogs, bikes, kayaks, bbq, etc into the truck.
Went on GM website and here are the numbers from GM
Ext cab, long box (4WD)6.6L Diesel:
Payload (lb / kg): 2725 / 1236
Trailer towing maximum with fifth-wheel hitch (lb / kg:
4WD w/ 6.6L (3.73 axle): 15700 / 7122
I really do not think that I will be over my payload and definitely not over towing capacity
Dave
Look on the sticker on your driver's door jamb. It will give the payload for your specific truck. I believe you may be a bit over when all is said and done.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
