- Y-GuyModeratorGet the numbers for the 2500 you are looking at, with those weight numbers we can give you better advice. Just because somebody is towing something with at 2500 doesn't mean its the ideal setup, many wish they had the 1-ton or 1-ton/dually.
- gattorgetterExplorerI kind of wanted to see what others were doing in the 2500 hd, and to hear from others what my options could be in 2500. That will decide if I want to go to 3500. But for right now 2500 hd truck is where I want to be.
- gattorgetterExplorer3500 is not out. Dually is out, needs to be daily driver. Diesel is about out as well, that stinkin dpf box the design people placed is in the worse spot possible.
- qchunterExplorerIf you don't have a truck yet you might want to look at a 3500 and possibly a dually. Then you can get the TH that you want and the size of a garage that will work for you.
- gattorgetterExplorerIdealy my SxS polaris ranger xp900. But it may not fit with tracks on. So a golfcart and 1000 lb smoker cooker, perhaps just a quad. Depends on where im going.
Most times this will be a 2nd home at fish camp and left there 80% of time. - lawnspecialtiesExplorerWhat will you be hauling in the TH? Motorcycle? Golf cart?
I like the Cougar SRX but the door is rather small. Probably only a motorcycle would fit. I also like the Puma Unleashed models but they are aluminum sided and some of the master bedrooms are somewhat little. - gattorgetterExplorerWell I started looking at the 14 ft garage range, too heavy. Now I am down to the 12/10 ( prolly 10 ft). The 2500 hd diesel payload is rather low, so Im gonna stick with gas.
- eDUBzExplorerTowing a 19footer with a 2500HD.I wouldn't narrow my search based off pics. There's a lot of option to consider, weight being the biggest then floor plan etc.
- gattorgetterExplorerLooking to get a TH next year 5th wheel. Will have a GM 2500 hd. So I guess I'm looking to see what 5th wheelTH are towed which that type of truck. Help narrow down the search a bit
- eDUBzExplorerWhat ideas are you trying to get ?
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
