- CaLBaRExplorer II
Me Again wrote:
So when I was towing the 5th wheel at 24,500 combined I towed at 60 MPH in 5th. Then came the little commuter TT with a combined 16K weight, and towing at 60 in 5th it got almost the same mileage was the heavier 5th wheel. So I have learned to tow without TH in slower areas like California and let it shift to 6th gear. In Az, Or and Wa I towed at 65-66 in 6th and mileage was better.
Thanks for the input. This sounds like a good idea as the Cummins and Aisin only shift to 6th over about 64 to 65 MPH from what I have noticed in tow/haul mode and I highly doubt that towing a 10,000 lb bumper pull will be a problem in 6th at 60 MPH.
Rob - Me_AgainExplorer IIISo when I was towing the 5th wheel at 24,500 combined I towed at 60 MPH in 5th. Then came the little commuter TT with a combined 16K weight, and towing at 60 in 5th it got almost the same mileage was the heavier 5th wheel. So I have learned to tow without TH in slower areas like California and let it shift to 6th gear. In Az, Or and Wa I towed at 65-66 in 6th and mileage was better.
- Cummins12V98Explorer IIIYES, I screwed up! I was looking for my pic with it in 5th gear.
- buckyExplorer II
NJRVer wrote:
??? Looks like about 1400 at 62:)
Got him! - FlanExplorerWas just out on the highway, 2019 6.7 2500 3.73s 68rfe
1800 in 6th 70mph
2375 in 5th 70mph - NJRVerExplorer??? Looks like about 1400 at 62:)
- Cummins12V98Explorer IIILooks like about 1,375 @ 62mph.
- valhalla360Navigator
ShinerBock wrote:
valhalla360 wrote:
M.R.E. wrote:
I have a '16 Ram 2500 CTD that I love except towing. I wish it had the 3.73 rearend instead of the 3.42. What is your rpm at 7o mph in 5th and 6th gears ?
You do realize the newer trucks have an 8 speed transmission, be careful that you are comparing apples to apples.
Only the gas engines have the 8 speed. The diesel's have the same 6 speed trans as previous year models.
Caught me on that one.
In that case 9% higher with the different rear end. - JKJavelinExplorer III2018 Ram Cummins 3.42
When towing my 11,000 5er, if I let it shift into 6th at around 1200 rpm @65 mph, anything more than a slight uphill grade, will cause it to drop to 5th gear. If I keep it in 5th gear, around 1700 rpm @65 mph, it will stay in 5th for most hills...not talking mountains here.
So most of the time I keep it in 5th and I usually use the cruise control.
JK - Cummins12V98Explorer IIIMy 11 HO DRW had 3.42's and I loved them. ONLY issue was getting the load rolling on a steep grade with the 68RFE. AISIN cures that issue. I was only towing a combined 29k.
I towed in 5th at 1,750rpm at 60. SAME rpm as my current DRW with 4.10's at 60. PERFECT rpm's.
IMHO 3.73's are the bastard gearing in the 4th gen trucks.
44,066 PostsLatest Activity: Oct 04, 2013
