kaydeejay
May 18, 2014Explorer
ADIRKS30 wrote:You are correct as far as engine/transmission are concerned. Maybe even the rear axle BUT last time I looked, on the GMs at least, the duallies have larger and thicker rear brakes.
FYI: Most all makes of the 3 trucks, GMC, Ford, and Dodge, it makes no difference in engine or transmission if you go from 2500 to 3500, the biggest difference for the higher towing ratings is the stability of the dual rear wheels, and the springs are probably a little heavier. This is a very common misconception, not just picking on this poster
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
