- WindowmanExplorerDoes anyone know how deep you can go with the awning? The guy I got it from said it was replaced new when he got it but it is about 18” short on each end. To me it does seem to go out very far, maybe 6’ and I would like to get it the biggest I can and the dealer just keeps saying that they all are standard and go out the same distance but I disagreed with him telling him that I think someone bought it off someone else just to put it on to sell it.
lincster wrote:
Freshwater tank should be cleaned with bleach once a year. Fill up with water, add a bunch of bleach, run through all faucets, let sit for 24 hours, drain and refill to flush out.
Black and Grey tanks, just dump normally.
You can add bags of ice to the black before you go out and tow, that helps sometimes.
If you want the genny to run well, run it at least 1 time per month for at least 30 mins.
You can put any wheel you want on the trailer that will fit. Trailer wheels have a 0 offset. This is for the bearings and keeping the load minimal.
If you google Weekend Warrior parts, there is a website that sells alot of Warrior parts.
what Linc said will help. It may take multiple times. I've never tried it but several swear by the Geo Method. Search the forums or google it. Lots of videos on it.- lincsterExplorerFuel tank for toys is 40 gallons.
Fuel tank for genny is 20 gallons. - WindowmanExplorer
Grit dog wrote:
150 fresh
50 gray
50 black
Is what I found in a quick search.
I have in this order of the tanks I see underneath front to rear, and what I found online.
Gray water 50 gal
Black water 50 gal
Fresh water 75 gal
Fresh water 75 gal
Gray water 50 gal
Fuel tank (big for the toys)
Fuel tank (small for generator) - WindowmanExplorerHow can I tell if my kicker amp is working or not, there are no lights that come on at all.
Also I’m not sure how to use the fader to see if the rest of the speakers are working (4 in the main living/kitchen and the two outside even thou the speaker wires are connected to them) - Grit_dogTrailblazer150 fresh
50 gray
50 black
Is what I found in a quick search. - WindowmanExplorerAnyone have an idea of the fresh water tank sizes that are on these?
I’ve been trying to get the specs on this and can’t really find it. I can’t find any tags anywhere on this rv at all. Would there be anywhere that one might be hidden on here somewhere? - Nv_GuyExplorer III
Windowman wrote:
Hap I did shoot you an email, if you could send anything you might have for this 5th wheel. It would be greatly appreciated.
Also any help on the radio and speakers on any access points since the cables are inside the walls, I have access to the ones behind the radio but was wondering if there are other areas.
Thanks.
Having worked at an RV dealer that sold a ton of Warriors I can tell you that the access point for wiring for the ceiling is the speaker closest to the entry door. Remove the speaker and feel around, you will find a huge wad of wires.
Good luck. Wiring was not Warrior's strong point, but they did build a darn tough coach. I had an FS2600, lots of miles and good memories with it. - dedmistonModerator
Windowman wrote:
I don’t have a stereo removing tool
Stop by your local car stereo shop and ask if you can bum a set from the techs. The two tools come with every new head unit, so they probably have a dumpster full of them. - WindowmanExplorerHas anyone decided to change the refrigerator in one of these and if so to what is involved with it?
About Fifth Wheel Group
