joe_blow's avatar
joe_blow
Weekend Warrior flooring
Hi all,
I was considering redoing the flooring from the kitchen up the stairs and into the bedroom (bath included) using laminate faux wood plank. I plan on leaving the storage area as is with the gray coin flooring.
Has anyone taken on this project?
What flooring did you use and where did you buy it?
Any pics?
thanks
  • busterja21 wrote:
    try coretec pro plus, its suitable for non-climate controlled installations. you can order it from most tile & flooring\carpet stores.
    This is info I was looking for. The vinyl stuff from HD and Lowes will have warnings not to use in extreme temp swings or non-climate controlled environments.
  • try coretec pro plus, its suitable for non-climate controlled installations. you can order it from most tile & flooring\carpet stores.
  • Where do you get the flooring and any specific brand?
  • you might do a search in the overall forums, there are lots that have done this. Like agteacher said it can get heavy though so choose material wisely
  • I have seen it done with vinyl flooring in the wood pattern to keep the weight down.
