N-Trouble
Jun 07, 2017Explorer
See my sig. Those smaller 28ft 5ers are perfect for a newer 3/4 ton. I came from a 21ft WW Superlite bumper pull. The 5er while heavier is a much nicer pull. I get nearly identical mileage on the flats and only a little less pulling hills. No regrets. Do it!
You will have to contend with the added height depending on where you camp so keep that in mind.
One thing I would look at in regards to the trailers is whether they are spring over or spring under suspension. I had to do a spring over flip to get a level tow behind my truck. The added stresses from the spring over causes horizontal stress cracks in my frame between the axles. Lippert took care of it and sured it up with three cross members but it is something I would have tried to avoid if I had known.
About Fifth Wheel Group
Related Content
- Feb 01, 2026Community Alumni
