Dwight45
Aug 27, 2014Explorer
Yep, might not have enough ground clearance to get up the ramp without dragging the tail. Since its a trike you could use 3 short loading ramps (make your own out of 2 X 12's) to transition up on the ramp. You may also have to block up the ramp a little so it won't high center when you're rolling off the ramp into the garage. If your garage has a dovetail you might be ok without blocking up the ramp. By the way I used the wheel chocks to block up the ramp.
Dwight
Dwight
About Fifth Wheel Group
