- CA_TravelerExplorer IIII vote for using wing nuts - better that they steal the battery than the RV.
- swimmer_speExplorer
GDS-3950BH wrote:
Wing Nuts, helping sidecutter or linesman pliers deficient thieves steal batteries since 1852.
It will take them a few minutes just to get to the battery on my good TT. It is not just out in the open on the tongue. There is a cover that has a wing nut holding it down over the battery box and propane tanks. It makes noise to remove the cover. Then 2 wing nuts for the battery, and 1 wing nut holding down the propane. Not a quick, easy or quiet process. - swimmer_speExplorer
CA Traveler wrote:
swimmer_spe wrote:
Your battery is compromised even if it apparently charges up. Have the battery LOAD TESTED.
OP here
So, I was going to need wing nuts for one of the batteries. Turns out it is stone dead. So, I will see if a local auto service shop can charge it as mine can't. If not,t he need for wing nuts is the least of my worries.
But regardless it's highly advisable to replace both batteries.
I planned that once it was charged to have them load test it too. I will try the parallel charge first. If it works, then I will bring them to be load tested. I have one battery that I know is a year old. The others are older than that, but not sure of. - swimmer_speExplorer
Fisherman wrote:
swimmer_spe wrote:
OP here
If the battery is too far gone, hook it up in parallel with a good one and then hook up the charger. Some chargers need to "see" some voltage before they will begin charging.
It is one of my older ones that I had planned on replacing. Looks like I'll be replacing it slightly sooner than planned. - GDS-3950BHExplorerWing Nuts, helping sidecutter or linesman pliers deficient thieves steal batteries since 1852.
OP here
But regardless it's highly advisable to replace both batteries. - CapnCampnExplorer III
Yep, I had a dead truck battery this week, and hooked up my "smart" charger to it since it was closer than the dumb one.
Unfortunately the Bat was only showing 4V, so the charger thought it was only a 6V battery. It obediently went to work & charged it all the way up to 6V, and showed full! Still didn't start the truck though.
After that, I got the dumb charger & let them work in parallel for a while. :)
CC - FishermanExplorer
swimmer_spe wrote:
OP here
If the battery is too far gone, hook it up in parallel with a good one and then hook up the charger. Some chargers need to "see" some voltage before they will begin charging. - swimmer_speExplorerOP here
So, I was going to need wing nuts for one of the batteries. Turns out it is stone dead. So, I will see if a local auto service shop can charge it as mine can't. If not,t he need for wing nuts is the least of my worries. - mobeewanExplorer
Grit dog wrote:
mobeewan wrote:
Some are 3/8 inch & some are 7/16. Carry both.
You mean 5/16.
Yes 5/16 not 7/16.
