swimmer_spe
Apr 21, 2021Explorer
CA Traveler wrote:swimmer_spe wrote:Your battery is compromised even if it apparently charges up. Have the battery LOAD TESTED.
OP here
So, I was going to need wing nuts for one of the batteries. Turns out it is stone dead. So, I will see if a local auto service shop can charge it as mine can't. If not,t he need for wing nuts is the least of my worries.
But regardless it's highly advisable to replace both batteries.
I planned that once it was charged to have them load test it too. I will try the parallel charge first. If it works, then I will bring them to be load tested. I have one battery that I know is a year old. The others are older than that, but not sure of.
