NRA4ever
Aug 27, 2014Explorer
Dwight45 wrote:
Yep, might not have enough ground clearance to get up the ramp without dragging the tail. Since its a trike you could use 3 short loading ramps (make your own out of 2 X 12's) to transition up on the ramp. You may also have to block up the ramp a little so it won't high center when you're rolling off the ramp into the garage. If your garage has a dovetail you might be ok without blocking up the ramp. By the way I used the wheel chocks to block up the ramp.
Dwight
That is exactly my concern. There is a dove tail on top. The height of the ramp is 32 in. The length is 8 ft 7 in. Box is plenty wide and long....12 feet. Great idea on the wheel chocks
I did not know there was a weight issue. How long should the 2x12s be? The trike is about 1100 lbs.
About Fifth Wheel Group
