theoldwizard1
Feb 24, 2017Explorer II
1L243 wrote:
No that's not right. When four 12 volts wired Parallel the voltage will remain 12 volts but the amp hours are increased. If wired in Series you would get the increase in volts... So you want to wire 12 volts in parallel to remain as 12 volts.
The bottom line is four 12V batteries could be wired to 12V, 24V or 48V ! Until we see the wiring diagram/picture or the OP measures the output of the battery bank, we don't know.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
