Lantley
Mar 08, 2014Nomad
Be very diligent and patient.CHECK EVERYTHING! That means every: latch, catch, knob,outlet,valve,switch,connection,slide,furnace a/c,faucet etc.
Picking up a new RV is an exciting time but curb your enthusiasm and go over everything. Go room by room and check everything in the room. If you discover something broke when you get own consider it your own fault!
Check operation of windows,locks, fans. Check it all.
Make sure ecerything is working to your satisfaction. If things are not right do not accept RV. Let them know you will return to pick it up when it is ready.
As long as you refuse to accept leverage is on your side and the dealership will respond. Once you sign leverage goes back to the dealer and you are now just a warranty claim!
The PDI is a very critical/important step in the buying process that most consumers take for granted and do not perform a critical enough inspection.
Make it clear to the dealer that you will be awhile. Take your time check rooms all joints etc. look around beneath the RV as well.
Assume nothing works until you test it!
About Fifth Wheel Group
