Dumoldles wrote:
I believe the bolt that broke is called a cross bolt, I have had it happen before. It happened while the slide was being adjusted at my dealer in Saint George, Utah. Talking with the tech that fixed it this last time, he said the bolt shears when it becomes loose; another item to check while on the road.
I may start carrying extras because the process doesn't seem that difficult. Lining up the hole, dropping in the bolt and tightening.
Dumoldles
Got to be sure the slide is aligned, though. Might want to mark the rack against the frame, just to be sure.
Lyle
