RVUSA wrote:
MrVan wrote:
Here is the part I have trouble understanding. When RV owners switch from ST Tires to LT tires do they also suddenly no longer underinflate or overload them? If most ST tire failures are due to under inflation and overloading why do those same RV owners have so much better luck with LT tires? Are these same RV owners inoculated with something when LT tires are installed? The ST defenders argument's don't hold water IMHO.
That is the one test that LT tires have done and ST tires dont on their way to getting the DOT stamp. Underinflation at speed.
The construction of the two are different. The ST sidewalls are built stiffer and because of that they heat up faster and farther than LT's when underinflated. They pretty much have to be run at max psi because of their makeup. The LT's are fairly forgiving in that regard as they have to meet the testing for that.
One other point (just for reference) is to go from ST to LT you generally have to go up in size on the LT to regain the carrying capacity that the ST had. Thats because of the sidewall construction isnt as stiff on the LT. So once you get the right LT size you are good to go with a cooler running tire.
Guess you have never handled a Michelin XPS Rib or Bridgestone Duravis R250. These two tires are the best LT tires for trailer use available period. They are built similar the the Goodyear G14. All three DO NOT have soft fixable sidewalls.
Flex in a sidewall is what builds heat, not the other way around. Goodyear even markets their Marathon ST tire as an economical tire, where as there is no doubt that their G614 is their high quality trailer tire.
Out on the highway at freeway speeds in hot weather separates the good from the bad pretty fast. We read about the bad in threads like this all the time. And guess what, the Marathon has had the much ballyhooed Nylon overlay for years, that some think is going to solve the mystery of ST tire failures!
Both my Ribs and now my R250s run cooler than the Michelin LTX M&S on my tow vehicle, in the 115-119 degree range when the TV tires are at 125 degrees, this in the SW 90+ temps fall and spring. People report ST tires run in the 135-150 range under these conditions.
It is hard to understand how anyone would want a tire that the manufacturer says has a 3-5 year life, is good for only 8000-12000 miles and should have at least 20 percent margin in loading.
Then we could talk about the stability of towing a trailer with a steel ply carcass tire verses baseball shaped ST tires.
Chris
