bad99ram
May 01, 2013Explorer
Goodyear Tires
I am just completing a 7500 mile trip in my new Fifth wheel that has the Goodyear Marathon tires owas passed by scores of other units.n it. I have had no problems with the tires but after driving all...
Mile High wrote:edatlanta wrote:That is kind of interesting, given the wheel manufacturers tailer the psi rating to the tire they are designed to wear. I wonder if there is actually a case where there the wheel is rated higher than the tire that is on it - beyond those that get changed around by the owners later.
I thought the second recommendation was interesting. Inflate to 25% over recommended maximum (if your wheels will handle it). Hmmmm, G rated tires would be inflated to 138 (I can't do this because my wheels are only rated to 110psi). E rated tires would need to be stored at 100 psi.
So if they recommend taking the weight off, I wonder if it is better to put the load on the hydraulic leveling system or tires while in storage.
