garyp4951 wrote:
Jeff1953 wrote:
sayoung wrote:
Put one of the underbed rail with turn over gooseball so you have both. Another option is just a turnover ball gooseneck & a B& W Companion that slips into the gooseneck ball shaft.
I use a Curt turnover gooseneck with a Curt X-Rail that mounts in the hole and use a B& W Patriot .
Really depends on how heavy a 5er your planning on. If real heavy look at the Traiersaver Airride hitches but B&W will take some really heavy ones also.
As luck would have it, I was actually looking at the B&W underbed mount gooseneck. I want to get the hitch before I have the bed Line-Xed. Most of the 5ers we've looked at so far are in the 9-11K dry weight range.
I would line-x it first, and not need to tape everything off, and they will not damage the liner when installing the turnover bracket.
I agree 100%. I installed my own TO Ball and helped my brother install his. Both our trucks had liner beforehand and had zero damage from the install and have had zero damage from our Companion hitches. (Doesn't mean that I haven't buggered up my liner from =other= use and abuse.) For a non-OEM GN/FW truck, there are 5 holes to drill; 1 4" hole for the ball mount and 4 1/2" holes for the safety chain loops. Just marked the liner and drilled right down through. I =did= spend the money on a 4" hole saw, and have used it several times for other projects, so it was money well spent.
Lyle
