Dayle1
Mar 17, 2015Explorer II
krazymatt wrote:
I understand what you're saying. For normal towing I don't see a problem unless you chained the 5er to a fixed object and yanked and jerked on it. Yes gs trailers have extreme gussets and heavy steel but then again they're made to tow backhoes and livestock. The ranch adapter I'm looking at is rated at 30,000lbs. If it was such a big deal I don't think Andersen would be in business. The trailer im getting is a 2003 so I could care less about warranties. Thanks
Weight rating of the adaptor is not the issue, the fiver frame is not rated for the extra leverage. So your unit is out of warranty, but IF the extra leverage does cause problems, repairs will cost about $5000. Doesn't seem to be worth the risk, considering the cost. Andersen states that some fivers don't have frames strong enough for the adaptor, but can't tell you which ones are OK. The trailer manufacturers can't tell you because it is not their design. And with the quality inconsistency in the RV industry, other owners can't tell you even if they have the same brand, model and year unit.
Finally, Andersen does understand the problem and that is why they designed the Ultimate hitch, which would be worth your consideration. The Ultimate is an elevated ball mount that attaches to the existing in floor ball socket. Because it is elevated, it is easier for the driver to see the ball for hitching. And being raised, it does not add significant leverage like other GN solutions. It is also the lightest, cheapest solution and they now have an aluminum version that is even lighter.
About Fifth Wheel Group
