Cummins12V98
Oct 02, 2015Explorer III
ralphnjoann wrote:
Cummins12v98 states:
"I think the Anderson is a good design, never have I said it's not I just don't think they are realistic on it's ratings.
If they would make one that directly attaches at the 4 corners say on a RAM with factory pucks then their ratings would be a bit more credible."
I thought the load rating of a hitch was calculated based its ability to safely carry the weight of the trailer, not the ability of the truck to support that weight. How does the configuration of the truck change the published ratings? It would be helpful if you would clarify your reasoning so all will have a better understanding. Thank you.
I have always thought the Andersen is OVER RATED when you compare it to the B&W hitch.
The point I am making is the base just sits on the sheet metal of the bed and WILL deflect it when the fore and aft forces of a large 5er are applied. By direct connecting the base to the pucks it would be an improvement in design IMHO.
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
