kzspree320 wrote:
Mine looks the same as yours almost. I had a GY Marathon do the same thing Memorial Day. Fifth wheel is 2014 model so tires were not old, I was driving 65 on the interstate, and the pressure was at 77 psi when I checked early in the morning. I had the Sailun S637s in 235/80-16 (G rated) installed today. I've also decided to invest in a TPMS system. The Sailuns are quite a bit heavier and stout. Good luck.
What rating is your rim? What psi are you using for your Sailun tires? I want to go to Sailun but I only have a rim rated for 80 psi. Sailun's tire chart has inflation table for 70psi to 110 so I believe you can lower psi to 80 but most forum replies say no should inflate to max rating on sidewall for ST tire?
