3159watson
Aug 31, 2014Explorer
GPS Garmin
I had to get a new Garmin while on the road through WV. She has taken us on every small road through downtown in this state. Garmin suggested getting the RV model. Does enybody have and information...
Paul Clancy wrote:There is exactly the right answer. Just putting a destination into a GPS, any GPS, is not the best way to use them. Treat it just like a map: plan your route out on a larger map, transfer the route to the GPS, and then double check to make sure it goes the way you planned. The 5 P's come into play here. :)
Really the way to use one for rv travel involves using the trip planner and then reviewing the trip to make sure it doesn't route you poorly. If it does you add weight points that keep you on a safe route. Just selecting a destination and pressing go will lead to many problems if not disaster with a large rig.
