shadoow
Jan 09, 2014Explorer
Jim-Linda wrote:
Again, its not how much it can pull, but how much can it CARRY. Take your smartphone/calculator along with the GVW of the trailer and see if the pin weight is less that 20% if the trailer GVW.
Jim
X2 this. The towing capabilities of a truck are essentially based on either what the truck can tow (pull) and what the truck can carry (weight). The salesman can very well be right when he says a 2500 can tow (pull) the trailer cause the truck's capability to do this is largely based on the drive train (eng, trans, etc.). BUT, usually the most limiting part of a trucks capability is what weight it can carry. For this you have to look at limits such as GVWR (Gross Vehicle Weight Rating), and front and rear axle weight ratings. As mentioned above, to determine a trucks ability to carry the load of a trailer hooked up you have to see if there's enough 'payload' which is the difference between the trucks GVWR and the actual weight of the truck, preferably weighed as it would be when going camping so it would include weights of all persons, pets, fuel, trailer hitch in bed, incidentals carried in the truck such as tools, firewood, whatever.
I know reading about all the different weights can really be confusing but it should be, IMO, a part of you must do to ensure you're towing safely for yourself and others.
About Fifth Wheel Group
