- drillkingExplorerDisc for me. Easy and no mess.
- FOREVER_FREEExplorerTeflon disk. Grease is for the big rigs. It would also be very messy and require constant re-greasing if you travel a lot. If your sitting in one spot for extended lengths it would be a good idea to apply a small amount of grease to keep rust from forming.
- gailgoldExplorerTeflon Disk. Works great, no mess. :-)
- 64thunderboltExplorer II
Rygar wrote:
Nothing but a teflon disk.
Works great for me.
Has worked for me for many yrs. All grease will do is attract sand, dirt etc. Plus get all over you if you have to get in the bed for any reason. - RygarExplorerNothing but a teflon disk.
Works great for me. - silvercorvetteExplorerI have a B&W Companion Hitch and use a white nylon disk (I just read the other posts, maybe the disk it teflon) with white grease top and bottom
- Cummins12V98Explorer IIISpend the extra money and get a 1/8" spacer from Hensley. It makes it much easier to see when there is clearance to unhitch.
Good call on the B&W! - jalichtyExplorerUsed a Teflon disk from 1993 through 2011 when we sold the FW. Never had a problem with it and very clean. Got one for our new FW as well.
- seleExplorerteflon disk for 8 years took, a year to smarten up
- 3_dog_nightsExplorer
lakeside013104 wrote:
I have a Hensley TS3 air bag hitch. I use the Teflon 1/8" thick disc only (available from Hensley). The 1/4" thick disc will not allow the jaws on the TS3 to close because the tolerance is so close on this hitch. This close pin to jaw tolerance removes any pin "slop" from the equation. No grease required on the disc. I do put a small amount of white lithium grease on the pin and the jaws of the hitch.
Lakeside
Have the same hitch, used an over the counter plate and it works fine.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
