fj12ryder
Jan 03, 2016Explorer III
After having disassembled the OEM legs, I don't see how a grease zerk on the side of the leg will add grease to the screw without pumping the leg partially full of grease. If you had the top of the inner leg level with the zerk you could pump some grease in and get on top of the inner leg. This might transfer a little grease to the screw but not very much.
You could drill a hole through both legs, mark the legs when the holes line up, and then use spray grease. That would put some grease on the screw, but in just one spot on the screw of course. Or spray grease up onto the screw from the bottom of the leg.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
