fj12ryder
Jan 03, 2016Explorer III
B.O. Plenty wrote:That's true as long as you're pumping grease above the inner leg. If the inner leg is up you may be pumping all that grease between the inner leg and outer leg, making one heck of a mess and doing little actual good.
I don't think you can over grease them. I would load them up with 8-10 pumps each. Won't hurt a thing, there are no seals to blow out. It just goes into a big open cavity.
B.O.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
