Theutzigs wrote:
Alright... I have a question..
I will admit.. We made a mistake when we were greasing the axles. I had a nail in a tire, jacked it up to remove the tire.
We saw the ez lube fitting and used a grease gun, to push grease in until I saw fresh grease coming out. Did it slowly.. Cougar 293SAB w/ Dexter EZ lube..
We did not rotate the tire as we did it.. We went ahead and did the rest of the tires.
(Look, I am aware I did it wrong and should have checked the manual.)
My question is this.. I am leaving Saturday on our trip..
What should I look for to see if I am gonna have issues? There is a rest stop 20 miles up the road that I will stop at...
I would not worry too much about it. Did you adjust the brakes as well? If so check the temps on the brakes at a stop. If that one is much cooler than the rest something may be wrong with the brake. It could be covered in grease or have another issue.
