Just had the guys at the shop pull my drums. Only one brake was working the other 3 covered in grease. Said I put to much in this spring. Metal on metal so don't over do it with grease
That's what EZ lube's do. Most people think they work fine until someone takes the hub off, then they find what your mechanic did. Don't use them. If bearings are packed properly, there is no reason to occasionaly squirt a little more grease in. They may eventually wear it out but they don't use it up.
