lee_worsdellExplorerAug 03, 2017greasing wheelsJust had the guys at the shop pull my drums. Only one brake was working the other 3 covered in grease. Said I put to much in this spring. Metal on metal so don't over do it with grease
azdryheatExplorerAug 03, 2017It is too easy to blow grease past the inner seal and onto the brake linings, which is why I don't do that procedure.
Related ContentWheel Bearings - re-grease?Best wheel bearing greaseGreasing wheel bearingsWheel bearing GreaseGrease on rear wheels
