Cummins12V98 wrote:
BigDinAZ wrote:
Cummins12V98 wrote:
Not to pop your bubble but your truck has 3.42’s NOT 3.73’s unless someone changed them.
You should have researched the truck before buying anything. A 12k 5er LOADED is a good rig for your truck.
Sure your truck will TOW IT but it won’t CARRY IT !!!
According to Chrystler.com here is the window sticker showing 3.73.
***Link Removed***https://www.chrysler.com/hostd/windowsticker/getWindowStickerPdf.do?vin=3C6UR5KL7JG303387
Aslo on the Ram towing guide page it says 17,100lbs Max towing and 2,270 Max Payload. Maybe I am missing something?
It's 3.42 plain and simple on "ANY SRW" newer Diesel RAM thru 2018.
It is on the window sticker, see yellow highlights. The one in the bottom of the left column states optional equipment may replace standard equipment.
The highlight in the second column from the left, is the 3.42 that comes standard with the CTD. As stated before 3.42 is the only available ratio in a CTD 2500 through 2018.
