Walaby wrote:
If you cannot weigh your truck, the previous chart can help. Looks like axle weight is neighborhood of 2900lbs. I would go with 3000. 6000-3000 is 3000 remaining axle capacity. Estimate 300 lbs for hitch (to be safe). Your pin weight cannot exceed that number (2700), which puts you in a 12,000 lb 5er category at best.
There is no way I could see you towing a 16,000 5er with your truck. It should/will likely have 3500-4000 pin weight.
Mike
So there are two stickers. One with weights, one with tires.
The one with weights says GAWR FRONT 6000#, GAWR REAR 6500# GVWR is 10,000#
The one with Tire info says Combined weight of occupants and cargo should never exceed 1,970#
I ooked on the sidewall of the tire and it says 3649# rating
Which one do I go by?
