alboy wrote:
Just for info sake your black tank sprayer has a check valve at the inlet that can fail and the tank will leak as it gets full.
Black tank would have to get REALLY FULL....so full that level would have to be starting to go up vent pipe
You see there is this 'anti-siphon vacuum device' installed HIGH up on that flush system to prevent/stop any backflow from tank.
If it actually did occur (high level..go thru spray nozzle then up 2' to anti-siphon vacuum device) it would leak inside RV where 'device is located'---typically under bathroom sink or even in a closet
