rockyd66's avatar
rockyd66
Grey Tank and Galley Tank
would like to find out if the grey tanks and galley tanks have safety valves or over flow mechanisms to bleed them when they get to full?? both my grey tank (shower & lav) in bathroom and galley tank leak when full,, galley tank just started
  • thanks guys this will help a lot ,,,I am fairly new at this rv business
  • All gray tanks I've ever seen do not have a safety valve or overflow. They just back up into the shower pan or sink when full. If your's leaks, you have a problem some place.
    Ron
  • Not really. Water typically backs up into the tub or sink.
    I would guess the pipe to tank connection is leaking.
  • Our grey tank has no safety, neither did our last trailer. Do you have a waste cap with the garden hose threads? If so, you can drain grey water continuously as you use it, provided you're in a place that doesn't prohibit it.
