Sam Spade wrote:
Can you....yes.
Should you......NO.
And what is going on with the black tank has no bearing on the right answer.
There are no "pros" except for being too lazy to go out and open the valve once a week or so......at the same time as you open the black valve.....which usually are side by side.
Well, Sam - you need to do some more detective work - or should that be "digging" before you suggest/accuse a poster of being lazy!..:(
Forgot the two things every plumber knows?..:@
(Only one of the two applies here)
Some folks have TWO gray tanks - the "normal" two (gray/black), and a completely separate gray for the kitchen.
For the (completely separate kitchen tank) set-up - leaving the kitchen gray open is fine - especially for us lazy types..:C
The black tank does have "bearing" (roller or ball?)..:S
Dumping the black tank contents, *followed* by the gray - helps move the black contents to the real sewer.
(The first of the two things every plumber knows)
Sooooo for the gray/black combo, as others have noted, "save" some (or all) of the gray contents to flush the lines and move the black tank contents after/following a black tank dump.
Open and dump the gray - as needed, when full and/or to facilitate a black tank dump.
The above is certified by Columbo as being the REAL deal!
:W
