- greendeExplorer IIAlso, turn off the breaker to your water heater and try it again. Sometimes the element will short across when it burns out. In fact, start by turning all the breakers off and flipping one at a time till it trips the house GFCI.
- ken_whiteExplorerThe large filter capacitors in the output stage of the AC-DC converter can develop quite a bit of leakage current as they age.
My guess is if you disconnect the converter on the AC side and test again you will not trip the GFCI. - n7bsnExplorerAlso the GFCI's in your rig can create a ground-fault when they are plugged to another GCFI. Usually this is because there is a hidden fault in one of the GCFIs
- rhochnadelExplorerYour ground and your neutral must be completely separate, the neutral cannot be grounded at any point in your rv. Believe that to be your problem, good luck! Master Electrician
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
