GottaRunGottaCa
Apr 10, 2019Explorer
MartyMoose wrote:
Thanks for the info.
Will check it out. It has to be much easier than pulling the main fuse.
I found this out the hard way, look at your owners manual and follow the procedure for Transport mode.
Mine is a 2015 CVO roadglide ultra, you have to turn on the ignition then immediately turn off, then press both turn signals at the same time until the turn signals flash three times, done deal your are ready to go, yours might be different.
:C
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
