azjeffh
Jan 28, 2017Explorer
rhagfo wrote:
If you are only 240# over GVWR and rear axle and tires are just under sounds like you are running a fiver on a max tow, not max payload F150.
If one is #240 lbs over their GVWR how could they not be exceeding the maximum payload rating? I understand not being over the FAWR, RAWR or GCWR. I also understand that the sum of the axels does not equal the GVWR of the truck as it's usually more. Is that what you're referring to?
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
