Njmurvin
Feb 17, 2017Explorer II
ol Bombero-JC wrote:
One more CA "thing' that some may not know, and only pertains to
CA registered vehicles and CA licensed drivers.
The Chippies *will* check DLs for the proper endorsement/s for drivers towing heavy trailers (toys inside) which require same.
(Three axles is a dead giveaway! - then just look at the trlr rating plate)
Not in possession of a Class A non-commercial DL, will rate a 'park it' - until a properly licensed driver is located.
True. And it doesn't take much for a TT to be in violation (>10K Lbs GVWR rating of the trailer whether loaded that heavy or not). For a 5th wheel, you have to be over 15k - but CA still requires a class C towing endorsement if GVWR of the trailer is between 10k - 15k.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
